Pez 90 - Phase 90 - distorts
Started by Luqqas, December 08, 2012, 05:43:24 PM
Luqqas
Hi there!
I've made Pez 90 from Tonepad. Phasing is correct, only that general effect level  is low and it distorts a little bit  if one hit strings normally.
I've tried changing the 150K resistor between base and collector of Q5 (put a 2N3906 with 250 hFE) as is indicated, but still distorts.
Any help?
Ok. This is it, definitely a passion.
"What to do when it doesn't work" , plus what kind of guitar, any buffers or boosters between guitar and P90?
Luqqas
Thanks, R.G. I know that article. I've read it.
Using an SG, no buffers and booster in between.
Publish voltages? I' ve founded pretty much correct, except that the reference voltage setting by 250K trimpot is 2.3V.. appears to low. And searching for another build reports on this forum, others stated 4.3V and similars
Quote from: Luqqas on December 08, 2012, 05:58:36 PM
The real question was "big guitar signal?", which could be from humbuckers, or some other pedal making the signal level bigger.
QuotePublish voltages? I' ve founded pretty much correct, except that the reference voltage setting by 250K trimpot is 2.3V.. appears to low. And searching for another build reports on this forum, others stated 4.3V and similars
That is low. The question is - why? That's one of the likely causes that made me ask for all the voltages.
Eric.nail
Need a schematic, layout and Lets get some pics!
I came, i saw, i taught little kids guitar for extorted prices.
