ad3208 delay GGG with 3pdt
Started by ilpfis, May 11, 2011, 05:30:27 AM
ilpfis
Hello, can you help please, i use a 3pdt switch for ad3208 analog delay of GGG, how you connect the pins ? if you have a small drawing that would be ideal... thanks
anchovie
The LED switching for that board is electronic, so you can just use two columns of pins on the 3PDT and leave the other column empty.
ilpfis
thanks for your solution, it is a really bypass ? can I connected with 3pdt normaly with led system (4,7k resistor) ?
ilpfis
Quote from: ilpfis on May 23, 2011, 04:26:05 PM
thanks for your solution, but I delete the système led for a connected standars (2X914 1x22k 1x4,7k and fet is out) and now it's no problem...
