Inductor questions
Started by Govmnt_Lacky, June 06, 2011, 09:44:14 PM
Govmnt_Lacky
I was able to dig up some 500mH inductors but I have a question as to whether or not they can be used for a wah circuit.
They are, as I said, rated at 500mH BUT.... they measure about 235 ohms resistance. I know that the usual whipple, fasel, etc measure far less than this however, could these inductors be used for a wah circuit? If so, what would need to be changed to compensate for the higher resistance
The inductors look like this but wrapped in plastic and they have flying leads:
http://www.hurricaneelectronics.com/images/inductor.jpg
Thanks for the help  ;D
Govmnt_Lacky
merlinb
#2
235 ohms is negligible compared with everything else in the (typical) circuit, so it won't be a problem (I make the maximum available Q about 26 which is still way beyond what you actually need). You can always increase the 33k damping resistor a little to compensate, but I doubt you'll actually need to.
Govmnt_Lacky
Quote from: merlinb on June 07, 2011, 10:18:07 AM
Thanks Merlin!  ;D
Next step is to slap it into a circuit and see how they sound!
Joe Hart
I have some old radios and TV's and such that have inductors. I wish I could measure their inductance. Is there any other way to tell? Do they have any markings like resistor color bands or the codes stamped on some capacitors?
-Joe Hart
Govmnt_Lacky
Quote from: Joe Hart on June 07, 2011, 11:02:09 AM
-Joe Hart
The inductors that I found have part numbers on them (how convenient) and they are even stamped as 500mH rating. I ran the part number through Google and it crossed to the real deal. So I decided to take some DMM resistance readings and they all measured between 230-242 ohms.
Brymus
The inductor on my Boss wah is a transformer,sounds good.
It measures 52R
I have a bunch of inductors and small transformers pulled from old TVs ect.
I am going to breadboard the Mc Coy circuit and see if any of them sound good.
I also have the small Radio Shack and Mouser trannies that are supposed to work so I will compare the lot.
Brymus
Quote from: Govmnt_Lacky on June 06, 2011, 09:44:14 PM
Is there any way you could measure yours (mm or inches) and count the windings (it doesnt look like many)
those look like several of the salvaged ones I have.
bluesman1218
Someday I'm gonna have to learn about inductors. I have been saving them whenever I strip a board. Are they the same as chokes? Like I said, gonna hafta learn 'em.  :icon_redface:
It's all about the tone!
Steve
POPA - Plain Old Power Attenuator AVAILABLE for PURCHASE soon!
Silvertone 1482 rebuilt - switchable Tweed, tube reverb, Baxandall + / Little Angel Chorus build, tons of Modded pedals
Govmnt_Lacky
Quote from: Brymus on June 07, 2011, 12:09:32 PM
That picture was only intended for reference  :icon_redface:
The actual inductor that I have has many, many, many more windings!  :icon_eek:
