Please help debog a EF40
Started by foozertone, June 06, 2011, 08:38:06 PM
foozertone
It only has clean signal in any state
2.it's the ef40 filter envelope follower
3. I used the GGG layout. I would link here but i can't figure how
4 Things I screwed up on this board: for one I changed r1 to10k instead of the 100k i originally used (anyone else find the color code frustrating?)  I also movedr4 to the4 back of the board cause I screwed  it up on front
voltage at board   9.3
ic1
1  2.12        8   9.38
2  0.2          7    2.13
3  1.6          6    1.9
4   0.00        5    8.2
I willl grately appreciate any help or comments
Thank you very much
Govmnt_Lacky
I am thinkin that you need to take a close look at R4.
I have not built this pedal YET.... but those voltages look wrong on the op amp. What op amp are you using?
Good news. It looks like you have V+ (power) and V- (ground) are on the correct pins.
Bad news. All the other pins look FUBAR!  :-\
Try taking a closer look around the Op amp for solder runs and take a closer look at R4.
Pictures of your board (both sides) would help a lot.
Good Luck  ;D
