TS808 vero help
Started by DonB, June 10, 2011, 02:52:36 AM
DonB
I made a TS808 on vero today. But when i engage it i just get ground humming.
Have checked my solders and cuts and all looks ok. The only thing i changed was a 220nf cap to 47u (all i had). Could that be the problem?
Also when engaged if i turn any of the controls i can hear the hum either change (tone) or cut off with the gain and volume.
DonB
I forgot to mention...
with the Electo caps the vero didnt say what way to orient them.
http://www.aronnelson.com/gallery/main.php/v/cpnyc23/layouts/TS808+Vero_CP.gif.html
the little grey area on the bottom of those electrolytics means - (negative) .   ;)
with vero there can be the tiniest piece of uncut copper where you cut......go over with a magnifier...or there may be a burr from where you cut
touching another line... :icon_cool:
220nf for a 47uf electro?....sounds the likely culprit to me... ;)
DonB
You got it the wrong way rounf. 47uf for a 220nf.
Im sure my cuts are all fine. Will look again. But i always inspect them with a light so i can see them properly.
did i?...... ::)
ok..yeah those vero cuts can look ok, till you get real close!..
anchovie
Did you see this in the comment box above the layout?
Quote*****seriously flawed layout********
DonB
Yes i noticed it just before.
I have ordered a pcb from www.guitarpcb.com. Will see how that goes. I also got a Boogie 57 and some 3pdt boards also.
