sequencer wah "ticks" when switched off
Started by ugly_guitar_guy, June 14, 2011, 11:43:12 AM
ugly_guitar_guy
So I finally got my sequencer wah (like Zvex Seek Wah) finished, and it really does sound awesome, but when the effect is switched off I can still hear a very quiet "tick-tick-tick-tick...." from the clock circuit coming through the amp. I can only guess that this is happening through the ground, even though I did my best to separate them as far apart as possible. I even tried putting in a 10M to ground resistor on the circuit, but then the pedal didn't want to work at all. Are there any thoughts on how I can eliminate this problem because I really want to use this pedal in my live pedalboard?
Check out my metal band here: www.facebook.com/hollowshell
or
my personal effects building page here: www.facebook.com/brotronics
Morocotopo
Maybe a low value resistor in series in the power line would limit current surges...(100R or so) I had an Easyvibe that bleed ticking to the other pedals through the power, and that took care of it.
Morocotopo
Any time you have a clock-like circuit, you are at risk for ticking.  Could be an LFO, could be a sequencer "stepper".  Same thing.
ugly_guitar_guy
Quote from: Mark Hammer on June 14, 2011, 02:14:14 PM
Well, the odd thing is that I have the sequencer set to inhibit and stay at stage 1 when it's switched off, so I don't understand why I'm still hearing the stage ticking. I guess I'll mess with some low value resistors and see what happens.
or
Quote from: ugly_guitar_guy on June 14, 2011, 02:18:14 PM
Inhibit stops the sequencer from sequencing. It doesn't stop the clock.
tiges_ tendres
What kind of bypass are you using?  Maybe try grounded input style?
Try a little tenderness.
cloudscapes
Quote from: tiges_ tendres on June 14, 2011, 05:11:20 PM
I was just about to mention this. I think I've fixed a number of noise issues when bypassed like this.
make it so that for the 3 lugs (usually 2 are used, but 3 should be available) that take care of the bypass LED, the center switch lug is grounded, the effect active lug to the LED, and the effect output to the final remaining lug.
so that when the effect is engaged, the LED is grounded and lights up, but when bypassed, the effect's output is grounded.
{DIY blog}
{www.dronecloud.org}
ugly_guitar_guy
Yup, I made sure to use grounded input style because I thought that would avoid this issue.
or
Are you using the ring terminal on the input jack to turn the power on when a plug is inserted?
ugly_guitar_guy
Quote from: R.G. on June 14, 2011, 07:31:00 PM
No, it's always "on," just set to inhibit when the effect is bypassed.
or
