any problems using a tl074 for wah and lfo on the same quad?..
Started by deadastronaut, June 21, 2011, 08:00:47 AM
would this be ok, or would/could there be noise problems?...
am i better off using 2x  072's?...
It can work fine using a quad, but if you do get any problems with the LFO bleeding into the audio there's very little you can do to get rid of it. Using separate chips for the LFO and audio is the best thing to do.
cheers ian, hmmmm...thought as much!..you just saved me doing a headache of a layout....thanks.... :icon_mrgreen:
In general, the crosstalk inside a dual or quad opamp is specified in the datasheet. For the 074 is it so low as to be a non-problem with any reasonable audio.
However, my personal preference is to use duals instead of quads because it makes layout easier, more flexible, and more straightforward.
Quote from: R.G. on June 21, 2011, 09:14:45 AM
very true!...i'll keep it simple.. ;)
