What to put in it?
Started by vendettav, June 19, 2011, 09:50:32 AM
vendettav
Ok so i have this little enclosure from power supply that I converted into a pedal enclosure years ago. the pedal didn't work so i threw it away. so now im thinking of what to put in there. So far i've got the following ideas: my populated prefboard of Metal simplex, Orange squeezer (which i dobut will fit) or the easy drive which screams like hell... hmmm I also have a SPST momentary off switch (normally on) and i was thinking of may be some noise making guitar machine that'd yell only when i'd push that button...
anyways ideas are welcome, i really want something sick-ish and something simple to fit in the box
check my music HERE
Shredtastic psycho metal!
digi2t
Quotehmmm I also have a SPST momentary off switch (normally on) and i was thinking of may be some noise making guitar machine that'd yell only when i'd push that button...
Wouldn't rather need a normally open switch for that? I mean, on when you step on it?
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
jammybstard
exactly how small are we talking?
You can fit a Tillman preamp in most things; but it's not exactly a noise making machine!
Death to the Intolerant
vendettav
Ive got a booster already so i'd want something noise making.
Dano: yeah i was thinking the same... :( thought tho you guys might suggest me something. hmm may be like taking off a component would yield an oscilation in some schematics.. idk...
the size is mm about 2x2x3 1/2 inches ( i think, but the inside is not 100% free it's got some wings on the walls and hwantot.. guess to hold a PSB or something) it's also got 3 holes for switches/pots and 2 holes for LEDs
check my music HERE
artifus
Quote from: digi2t on June 19, 2011, 10:10:11 AM
unless it was routing the noise output to ground? until you step on it? or could always be used as a stutter/momentary mute.
vendettav
Quote from: artifus on June 19, 2011, 12:35:29 PM
yeah i thought of noise to ground but that way all the signal would be grounded right? i bought it for some other application but never got to using it... also i have a killpot which is a pot and a kilswitch in one thing so i wouldn't need the stutter much
check my music HERE
artifus
only the signal you wished to mute. i was thinking more along the lines of parallel circuits, one a simple booster or fuzz/whatever and the other a simple noise generator/oscillator that has it's output signal grounded until released by the momentary switch maybe.
vendettav
Quote from: artifus on June 19, 2011, 02:22:53 PM
yeah i was thinking the same actually, but if i ground the end of the circuit, won't it affect the other circuit as well and jsut ground the whole signal? got any wiring ideas? :)
check my music HERE
twabelljr
What if it was a normally open momentary on the input or output side of the noise generator that completed the circuit when stepped on? Would there be popping or any other issues if there was no led?
Shine On !!!
