Problem with Small Stone tonepad
Started by lucasventura, July 21, 2011, 09:43:36 AM
lucasventura
Hello everybody! Before reporting my problem, I tell you guys that I looked in the forum, found the results just like my problem, but the guy did not post any more results. Moreover, the same result found in the old forum. Guys, is next st ... I'm riding the Small Stone phaser of tonepad. I assembled everything pretty ... clean welds ... checked in the build-up each track to check whether there was short between them .... Anyway, it took 5 hours riding, just very slowly to avoid problems. When I was testing with the case still open ... hit the pedal and could not hear the sound of the phaser ...
The sound is clean and still gain in smaller type. When I use the key color, on-on, to the other side of the sound disappears.
Well, I'm using the CA3080 IC's, transistors 2N5088 and BC560 2N5087 instead of inverted. The pot is 1MB. Some handmade can help me?
Already thank you guys
Ummagumma
did you swapped R2 (470R) with 100R?! (no, then you should) ;)
lucasventura
NO my friend!! I wil try now.... wait a minute
lucasventura
doesn't work my friend..... i am using the 1 Mb pot. This is a problem???
lucasventura
I'm measuring the power of the Ci's between pin 7 and 4 and the voltage is 0.95 V. Is something wrong?? Is this some transistor??
