bulb for Maestro Fuzz Phazzer?
Started by Rodgre, June 08, 2011, 04:29:20 AM
Rodgre
I'm repairing a Maestro FP3 Fuzz Phazzer. It is a treadle-controlled phaser, which actually makes it more of a wah (the treadle controls the sweep. There is no LFO).
On the board is a tiny bulb surrounded by 3 photocells. The light isn't working, though I get a voltage across it that changes from about 0 to 1.5v with the sweep of the pedal.
I've tried an LED but it does nothing.
What would any of you suggest I try instead?
I don't have the schematic but I can tell that the light is fed directly from a transistor. There is no resistor in line to remove for a higher voltage (say 3v for and LED).
Roger
Nasse
Maybe there is some markings on the lightbulb metal parts, like volts milliamps or something
Rodgre
No marking. It's a tiny bulb with no metal base. Just 2 tiny wires. Like a Grain of Wheat-type bulb from a model railroad.
Roger
LucifersTrip
I use red 2mm pinhole led's for all my 1.5v fuzzes...only red will work
http://www.futurlec.com/LED/LED2PINRpr.shtml
always think outside the box
MoltenVoltage
Mouser sells the incandescent lamps from Chicago Electric but they don't come cheap.
Those pinhole LEDs are too cool!
MoltenVoltage.com for PedalSync audio control chips - make programmable and MIDI-controlled analog pedals!
Rodgre
Update and more questions:
So I have tried every possible kind of LED/bulb in this circuit to no avail. I definitely get a modulating voltage when I put a meter across the pads where the light should be, but no bulb (ac/dc) or LED will light up in the circuit.  Is it possible that there is voltage but no/very little current? I don't have the schematic, but I was going to try to trace out the LFO circuit. The bulb seems to be driven directly from a transistor. I would swap out that transistor for the hell of it, but I'd rather understand what's really going on.
Is it possible to have voltage but no current?
Roger
