"A" / "2SA" series Japanese datasheets?
Started by LucifersTrip, July 30, 2011, 04:47:41 PM
LucifersTrip
I really thought it'd be very easy to find info on the common 2SA / 2SB / 2SC Japanese transistors, but it can be confusing.
Many times the "2S" is left out on the numbering on the plastic case silicon ones.
Here's the confusion:
This is clearly labeled as "A124", and you will see it listed in an inventory somewhere as "2SA124".  But, a "2SA124" is a metal case germanium.   This is clearly a plastic case silicon.
So, what are these plain "A" series silicon with low 3-digit numbers like the germaniums? What's a guess at when this "A124" was made?
...and can anyone find an actual datasheet for this?
thanx much
always think outside the box
Sometimes these are house numbers, unfortunately, meaning that they are a number used for someone else's internal inventory needs.
Occasionally - as in the case of the EH1048, which we all understand to be relabelled CA3094 chips - the numeric equivalence to another device is broadly shared information.  Other times, not so much.  There used to be a huge, and I mean immense, book printed in little tiny letters on onion-skin paper, which provided a cross-listing of all known semiconductors, including house numbers.  Not sure if a similar listing exists now, some 25 years after the last one I saw.
LucifersTrip
#2
In this case, it is not a house number. The A124 was from a Japanese seller...and it was advertised as 2SA124
At the time, the same seller had a full line of 2SA, 2SB, 2SC, etc...
...but there were these, which have the same number as the ge's without the "2S"
Is there a datasheet anywhere?
Here's what my databook says about it.  I've chopped the page just below 2SA124.
LucifersTrip
#4
Quote from: Mark Hammer on July 30, 2011, 08:37:32 PM
Thanx...though, this is the EXACT confusion I mentioned in my first post. I believe this is for the germanium 2SA124
http://www.datasheetarchive.com/dl/Databooks-1/52-27.pdf
http://transistor-spravochnik.ru/description/2sa124/7468
not, the A124 silicon (which, confusingly, is also listed as 2SA124 in some sale lists today)
I forgot to mention that my Peak Atlas shows the A124 as "PNP Digital" and does not show an hfe. With a quick search of PNP digital, they are listed as having built-in resistors
edit:
I think I finally found it.
This was a tough one....the A124 is listed side by side with probably what is a newer version, DTA124ES
It is a digital transistor. As I noted, my Peak Atlas does also show it as "PNP Digital"
I found a datasheet here:
http://www.datasheetarchive.com/dl/Datasheets-27/DSA-524494.pdf
