Add an extra volume pot to a 2 gain channel distortion box - questions...
Started by GeorgeSunset, September 01, 2011, 03:58:21 PM
GeorgeSunset
Hey, I'm trying to add an extra volume control to my overdrive (on for each gain channel – 2 gain channels)
The Circuit is much like a tube-screamer, so the switching between the gain pots is by switching between the output lug's of the pots (2x100k pot). It uses a DPDT switch (an LED turns on when switching on channel 2).
Could I just replace the switch with a 3PDT switch an switch between output lug's of the volume pots as well? Much like this (THANKS to "frequencycentral" for the diagram):
Should I double the ohms for both volume pots from the standard (5k std. would be 10k for 2 pots)?
Or doesn't it matter (just adding a 5k I parallel)? What would the result be? Less range?
Thanks for the help :)
(EDIT: fixing the picture)
> Could I just
Yes.
Use what you got handy. An "exact" answer needs more data, the usual problem is more distortion, but is sussposed to distort, so what's the problem?
GeorgeSunset
