Cheap (Or Free) Signal Generator Advice?
Started by iandy4, August 28, 2011, 12:36:18 AM
iandy4
Hi Guys,
I got my hands on a tektronix oscilloscope a while back but I haven't been using it much.  I now have several circuits I'd like to test, some balanced and some unbalanced, and I need a sine wave to put through the circuits.  I don't know how accurate my oscilloscope is so I figured it would be pretty important to have a decent signal generator for testing my various circuits and to confirm that my oscilloscope is working or needs calibrated.  Any advice would be greatly appreciated.
My Site:
jazbo8
http://www.infinitespectra.com/index.html Try the SG One. Free if you have a PC with a soundcard  ;)
Jaz
Gurner
#2
I think nowadays, if I were in the market for a cheap of free signal generator, I'd be llooking for a smartphone app, eg...
http://www.androidzoom.com/android_applications/media_and_video/soundform-signal-generator_gxbc.html
...the phone manafacturer has already graciously provided the siggen chassis, knobs & buttons (via a touchscreen), audio hw & power supply ....it just needs someone, somewhere to wire them all together via software in the order that a signal generator needs!
Audacity a free audio editor can generate sine waves, noise, frequency sweeps and a whole bunch of other stuff. It won't help with calibrating your scope but for testing circuits it should do what you want.
EATyourGuitar
the getlofi 555 is the simplest function generator. with a small signal transformer you can get the impedance a little more real world for guitar pedals. I use solid wire and a board mounted pot so I can plug it into the breadboard.
WWW.EATYOURGUITAR.COM <---- MY DIY STUFF
defaced
Quote from: iandy4 on August 28, 2011, 12:36:18 AM
Hi Guys,
Which scope?  The service manuals for the scopes I have go through the calibration procedure.  Also, alot of them have a built in signal generator (the 465 I have has a 3oomv 1kHz square wave) for basic stuff.
-Mike
iandy4
Thanks for the tips guys.  I downloaded audacity and it works just fine for my current needs.
My Site:
  Find the cheapest doodad with an output jack, something like a toy keyboard, provide PS and then tape 1 or more of the keys down, good strong output signal with piano/guitar/organ 'type' waves can be had for next to nothin.
Steve Mavronis
This free Soundcard Scope (http://www.zeitnitz.de/Christian/scope_en) includes a signal generator.
QuoteThe oscilloscope contains in addition a signal generator for 2 channels for Sine, Square, Triangular and Sawtooth wave forms in the frequency range from 0 to 20kHz.
Guitar > Neo-Classic 741 Overdrive > Boss NS2 Noise Suppressor > DOD BiFET Boost 410 > VHT Special 6 Ultra Combo Amp Input > Amp Send > MXR Carbon Copy Analog Delay > Boss RC3 Loop Station > Amp Return
