"motorboating" oscillation sound on a Tonebender Mark II
Started by mordechai, December 14, 2011, 10:16:28 AM
mordechai
I built a Tonebender Mark II circuit with a silicon PNP at Q2 that sounds great.  But I incorporated a 10KB pot between the battery and the -9V in to the circuit to follow the "dyning battery simulator" mod that I saw on the Beavis site.  When I turn the pot to reduce the flow current going into the circuit, I get a really bad "motor-boat" sort of oscillating sound.  Is there a way I can get rid of this?  Use a different value pot?  Swap out a different value Q2 (maybe high or lower gain?  It's currently around 90 Hfe).
If you don't want instability, the sag resistor must go on this side of the main filter cap:
