ITS8: Low volume
Started by WesMVaughan, September 19, 2011, 04:04:59 PM
WesMVaughan
The volume knob is turned all the way up and there is low volume...could this be an op amp? I had used it the night before and id nothing to it except pack it back up in the pedal box, then the next day, it was not working. There are no broken solder joints anywhere. I suspect the Op-amp is bad.
ugly_guitar_guy
Only one way to find out, take the DMM to it and get some voltage readings, then cross check it with the build instructions:
http://www.generalguitargadgets.com/pdf/ggg_its8_instruct.pdf
Btw, I just built mine this weekend. That pedal rules.
Check out my metal band here: www.facebook.com/hollowshell
or
my personal effects building page here: www.facebook.com/brotronics
WesMVaughan
Yea unfortunately I don't have one at the moment...weird thing is, I played it a week ago packed it up and then tried it out yesterday and had this problem.
WesMVaughan
There must be an obvious place to start if it is passing a signal but it is low...Like I said it was working for about 7 months prior to this.
