GGG ITS8 Weak Output
Started by Bill_N, September 19, 2011, 07:10:06 PM
Bill_N
Well, after sorting through basic stupid problems such as insulating a metal DC jack using a rubber grommet, and building General Guitar Gadgets' Tube Screamer clone without the clipping diode switch, I have ran into a problem with weak output. I have checked and rechecked all of my offboard wiring along with electrolytic cap, diode, and transistor orientation, and am scratching my head trying to figure out what to do to solve this problem. Anyways, here's the info.
Source of schematic: http://generalguitargadgets.com/pdf/ggg_its8_sc.pdf?phpMyAdmin=78482479fd7e7fc3768044a841b3e85a
Source of PCB Layout: http://generalguitargadgets.com/pdf/ggg_its8_lo_no_clipper_sw.pdf?phpMyAdmin=78482479fd7e7fc3768044a841b3e85a
Voltages:
IC1:
1: 5.2v
2: 5.4v
3: 5.12v
4: 0v
5: 5.2v
6: 5.2v
7: 5.2v
8: 10.5v
Q1:
B: 2.95v
C: 10.5v
E: 3.35v
Q2:
B: 3v
C: 10.5v
E: 3.46v
arawn
emitter voltages look high and your base should be a diode drop higher like .5-.7 that's the first thing i see.
"Consistency is the Hobgoblin of Small Minds!"
Gus Smalley clean boost, Whisker biscuit, Professor Tweed, Ruby w/bassman Mods, Dan Armstrong Orange Squeezer, Zvex SHO, ROG Mayqueen, Fetzer Valve, ROG UNO, LPB1, Blue Magic
Bill_N
Judging from the layout, could it mean that the transistor I used is in backwards, causing the low volume problem?
ugly_guitar_guy
Did you use the germanium diodes from the mod kit? I tried it and it was VERY quiet, so I went back to the 1N4148's and it was full volume like it was supposed to be.
Check out my metal band here: www.facebook.com/hollowshell
or
my personal effects building page here: www.facebook.com/brotronics
Bill_N
I used the 1n914 diodes in the feedback loop of the opamp as it is in the schematic. I have 50+ of the 1n4148s laying around so I will try that. That does make sense though, seeing as general guitar gadgets warned about the volume changes. The diode type probably has something to do with it. I will try the diode lift mod (removing diodes) from loop and see where that gets me before putting in the 1n4148s.
Bill_N
Edit: I did the diode lift modification and I still have the same problem.  ???
arawn
Check your transistor pinouts, I am thinking the output buffer maybe out of whack somehow and killing your signal
actually both buffers seem to be out of whack  so i would start there
Bill_N
These are the transistors I am using for this. I just noticed that the schematic calls for a pair of 2N4401s. I will check around the transistors for any bridges or bad joints. http://www.onsemi.com/pub_link/Collateral/2N3903-D.PDF
Bill_N
Could the transistor voltages be incorrect because of a bad bias voltage? Or would that not matter seeing as they provide no gain.
arawn
afraid i am now in over my head
stringsthings
Quote from: Bill_N on September 20, 2011, 11:31:17 PM
1) yes ... 2) it depends on how "bad" the bias voltage was
however, in this case:
Quote from: Bill_N on September 19, 2011, 07:10:06 PM
Q1:
B: 2.95v
C: 10.5v
E: 3.35v
Q2:
B: 3v
C: 10.5v
E: 3.46v
.. the voltages that you measured at the bases of the transistors are less than the voltages that you measured at the emitters ... that's probably not going to give you the results that you want ... for this particular part of the circuit to function, you want to see the voltage at the base be higher than the voltage at the emitter ... ( for example:  on Q1, Vb = 3.55 and Ve = 3.05 )  ... the same idea applies for Q2 ....
Bill_N
Well, fast forward a bit later and my ITS8 is working and functional! I made a huge error in ordering the film capacitors from mouser as 10mm spacing, thus making everything not have that good of a connection. I replaced all of the film caps with WIMA box film caps and now this pedal screams! Thank you for all of the help everyone!  :icon_biggrin:
