new overdrive "engine"
Started by earthtonesaudio, October 10, 2011, 05:46:08 PM
CynicalMan
Quote from: Skrogh on October 12, 2011, 06:03:04 PM
Looks like it morphs between Fuzz+clean and overdrive/distortion. Would be interesting to hear this! If you'd like, I can make an LTspice simulation tomorrow, LTspice can export wave-files. :)
Like I pointed out before, it just acts a gain control for a normal Tube-Screamer-like clipping stage. However, it keeps the peak level the same at all times, which could be useful in other OD designs.
Skrogh
Quote from: earthtonesaudio on October 14, 2011, 08:24:59 AM
Awesome, thanks Skrogh!  This is the first time I've heard a circuit before building or even breadboarding it.    :o
The real deal might sound a bit different - as i remember it, I used an ideal Op-amp for faster computing time. But hey, small part count, so should be easy to bread-board. ;)
@CynicalMan
I'm not sure I completely understand you? Something as in gain goes op -> volume gets adjusted accordingly?
