Big muff pi - new schematic
Started by HitTive, October 17, 2011, 01:38:39 PM
HitTive
Hi, i changed a schematic big muff pi from general gitar gadgets. Oryginal schematic: http://www.generalguitargadgets.com/pdf/ggg_bmp_wiring.pdf?phpMyAdmin=78482479fd7e7fc3768044a841b3e85a
This is my schematic:
It being work?
theundeadelvis
I don't think your layout (not a schematic) will work. You've put a jumper, where the positive lead of the LED was attached, to ground. You're effectively shorting your power to ground. I think you should just be able to leave the jumper and R27 out.
If it ain't broke...   ...it will be soon.
Govmnt_Lacky
If your only reason for the change was to NOT use the LED and to use a DPDT instead of a 3PDT, then all you need to do is remove that jumper (bypassing the LED) and remove R27. Then, wire it as you have it above.
That is ASSUMING this is your intention...  ;D
HitTive
Quote from: R.G. on October 17, 2011, 02:13:36 PM
Why did you change it??
I changed it because i want to try this effect. I will have 3pdt for 2 weeks.
Thanks for help.
Sorry for my english.
