Valvecaster Problems help!
Started by lightning, October 10, 2011, 02:45:36 AM
lightning
So I have been pulling my hair out building the matsumin valvecaster pedal.
I have checked my wiring to the schematic/wiring diagram countless times.
Checked my solder points... and
I was wondering why my grounded pins of the 12ax7 socket were reading voltage.
( I am fairly new to building pedals I have only accomplished a working bazz fuss
and the matsumin valvecaster seemed like a good beginner project.
and at pin 2 there was no voltage reading, and at pins 4 and 8 which are grounded do
have a significant voltage reading.
My readings are essentially the opposite of a working valvecaster.
HELP
nomorebetts
Which layout did you use as pin 5 should have voltage not pin 2.
Also what kind of power adapter are you using?
Look for the negative polarity symbol as thats what the regular boss style adapters are:
http://en.wikipedia.org/wiki/File:AC_adaptor_polarity.png
I like Big Muffs! and I cannot lie, you other brothers can't deny...
