Dr boogey - what is wrong?
Started by HitTive, November 12, 2011, 11:11:50 AM
arma61
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
HitTive
Voltage on drain of Q1,Q3,Q4 is near 4,5V.
Voltage on drain of Q2 is 0,3V . (This is a max voltage which i can set)
Voltage on drain of Q5 is 9v.
Change:
Pot 25k --> 20k,
Pot t 2,5k --> 2k.
30nF --> 33nF
5nF --> 4,7 nF.
The sound from amplifier is clean, no gain.
whats that  scheme applied?   ???
looks like you have out to ground on that....out is from vol 2 (miidle lug)..........where is  9v going?....
draw up something a little better man!... your connections i mean ..with text too...
it'll help us to help you....
http://gaussmarkov.net/wordpress/thoughts/wiring-up-a-1590b/
HitTive
arma61
I know it's a stupid question... but  have you installed the jumps?
one of that, the first pink line on the left,  is bringing GND to the Gain pot and to R6, C6, C5, C15, components that are surrounding Q2, that's where you have voltage issue.
also go at page 2 of the following docs, from GGG to check voltages at other pins of Qs
http://www.generalguitargadgets.com/pdf/ggg_bsiab2_instruct.pdf?phpMyAdmin=78482479fd7e7fc3768044a841b3e85a
not sure if Qs have the same numbering but you can compare with Gus schemo.
Ciao
