switching effect b/w line and effects loop?
Started by dubs, January 01, 2012, 05:42:27 PM
dubs
Hi there,
I'm tinkering with an idea for a effect/preamp circuit and a true bypass effects loop. There would be three switches:
1. to turn the preamp on/off
2. to switch the looper on/off
3. to route the preamp to be in line (i.e. after the input jack so preamp is the signal path whether looper is on or not), or just in the true bypass effects loop.
Here's how I initially wired up:
I know there's something not right with the switch to switch preamp in line or in the loop- my brain has gone fuzzy!
I haven't included in any grounding etc at the moment, just working out the signal path at this stage.
Any help is appreciated. Thanks in advance.
daz
dubs
Quote from: PRR on January 01, 2012, 10:37:48 PM
Thanks and mich appreciate  the diagram, but I probably didn't explain it well enough.
I'd like the selector switch to assign the preamp to be  in the signal chain independent of the looper, or just in the looper section ( so if you switch the looper off, the preamp will be bypassed). It's not that straightforward as it needs to consider what else is happening to the signal when the other footswitches are turned on.
Cheers!
