How many milliamp?
Started by hazefuzz, January 12, 2012, 04:31:58 PM
hazefuzz
hi,
I would like to know if someone could tell me an easy way to know how many milliamp have a stompbox,
thanks
I'm french, sorry for mistakes
CurtisWCole
Composers shouldn't think too much - it interferes with their plagiarism.
Howard Dietz
hazefuzz
thank you CurtisWCole and thank you to Beavis audio for his great post
1    Insert a plug into the pedal's input jack so it is powered on
2    Press the stompswitch so the pedal is on
3    Pop open the pedal so you have access to the battery clip
4    Connect only the positive side of the battery
5    Set your multi-meter to read mA values in the 2-200mA range
6    Connect the meter's probe in series with the battery and battery clip
7    Measure the current draw
CurtisWCole
Always glad to give back when the opportunity arises.
Curtis
Howard Dietz
