General overdrive / boost question
Started by chaz, January 27, 2012, 05:44:27 PM
chaz
I've been playing around with my Fulltone FD-2 lately and it seems as though I can get a pretty substantial amount of boost over my clean channel with this thing (significant volume change).
However when I switch to one of the dirty channels on my amp and activate the boost, it merely tightens up the sound a little bit (classic metal sound).
Can anyone give a technical reason why there is not as large of a volume boost over a distorted channel but a pretty huge boost with the clean channel?
aron
Headroom. There's not as much headroom in the overdrive channel.
chaz
So is the only way to get a boost on a distorted channel to have a seperate switched volume control between pre-amp and power amp stages?
Put 8 inches of stuff in a 4 inch pipe. Get pretty dense.
> dirty channels ... merely tightens up
Put that 8"-into-4" stuff into another 4 inch pipe, it can't get much denser.
