fernandes sustainer guitar run off of an AC adapter (wall wart)
Started by petey twofinger, January 26, 2012, 04:53:20 AM
petey twofinger
i got one and it seems to eat batteries . its actually a fernandes , i think its an older model revolver . it doesn't have the harmonic mode , just on off sustainer . i THINK the pu's are active though ... not sure . either way i have a THING about small batteries , and i have a collection of sla 12 volters , 2 deep cell gell cells , 2 reg deep cells , etc . i REFUSE to use small batteries , period . but i am kind of a goof when it comes to knowing the ins and outs of this stuff , i need to learn . always worried about frying stuff , cause i did once 20 years ago plugging a boom box into a cig lighter in my car ...
i made a mini amp with a 12 volt sla in it , there is an automotive phone charger type teansformer that i cut in to get 4.5 volts for the korg pandora that is the amps front end . i also have ac in it with ac adapter , 4.5 volts for at home .
i was thinking , can i do the same thing , get a coupla adapters for 9 volts , one dc adapter , like a phone charger , then a 9 volt say 300 or 100 ma wall wart and have thhose power the sustainiac circuit .
ideally i would figure out a single cable set up , like hack a 3 conductor mic cable , then run the dc on the ring or  something . of course i could blow something , unless i got a proper slow blow fuse or switch (preferably not in the guitar) . i am concerned about audio interference though . dont really want to go thru all the hassle and then find out it wont work .
anyone mess with this idea before ?
what should i do ?
i do have a long length of shielded 4 conducter cable , i could go standard mono 1/4 inch the have lil power wires come outta the back of the jack into some lil 2 conducter clips . something cheesy . but ..
i tried a few power supplys using a 9 volt battery clip tonight with different results . some seemed to make the sustainer too strong , like all the strings were singing loudly . when i had run it , the battery wasnt fully charged and it worked well , but one string at a time . curious about this , is it the milliamps rating or the volts thats gonna make it work harder , it was tought to determine what was going on . some power supplys , the one was a multi voltage , i could set it at the 4.5 volt setting and it still sang , yet the lower voltage 9 volt battery didnt work . also could i lower the sustainer pick up ? it is kinda high . i guess it would be neat to use the adjustable adapter and have different settings , but i do not want to over power or harm the circuit in ANY way !!
anyone ran one of these "hot" like with too much voltage ?
hmmm , i am really outta my league here . i looked around online , didnt find much . the sustainiac page says use a seperate cable to feed dc . it also says NEVER have the auido ground and the dc ground connected . when i used my meter i got continuty between the neg battery terminal and the neg guitar auido jack ... seemed a contradiction , but this is not a sustainiac product , its a fernandes , they are different , correct ?
like i said , i am such a goof , thanks in advance !!!
oh yeah ,  i also sent psw a message .
im learning , we'll thats what i keep telling myself
ashcat_lt
This kind of thing keeps coming up, and the big problem always cited is the possibility of a short while plugging.  Can anybody provide a fairly simple current-limited power supply circuit so we can put this thing to rest?  I suppose the sustainer will want more current than most other on-board effects, but...
gritz
Yeah, custom leads are a faff, especially if you play live and don't have a spare...
Maybe a rechargeable battery pack mounted on your strap (wireless transmitter style) would be a workable compromise. A 7v2 NiMH and charger robbed from a radio control car / plane perhaps (I have an old radio that I've done this to). Just be aware that these batteries can kick out a lot of amps when shorted, so take appropriate precautions.
Hope this helps.
FastJunkie
Perhaps a bit overkill, but would work nonetheless:
Replace your 1/4" jack with an XLR and run that into a box that simply pass the signal through and puts 9vDC through the 3rd conductor.
petey twofinger
the rechargable nihm was my original idea . plus i have everything to do it here . got a 9.6 volt nihm and a charger from resale for super cheap . different manufacturer so there is some connector hacking to do .
it just seemed kinda clumsy , also i was concerned about the battery life on the nihm cell . i guess i should start doing this one step at a time . cut the power input into the guitar and go from there . i admit i didnt think about the possability of shorting that battery , good point that i overlooked . any suggestions on that concept ?
i am guessing a fuse , which brings me to the question of what value and type .
the most logical thing at this point is to put a separate input connector for the dc in on the guitar , close to the audio jack .
the nihm cell is a lot larger than a 9 volt cell , but dang is it light weight . i will start here , thanks .
space_ryerson
I've had some decent luck with 9V rechargeables (sized like a normal 9V battery) and my sustainer (non fernandes guitar). You could use two 9V rechargeables in parallel inside the guitar to get more time before needing to recharge.
petey twofinger
not sure if this nihm cell is dead , but i dont have the legit charger . it read 9.4 when i got it . recharged it , ran it foer 5 minutes and it was 8.44 charging it now at 10.55 volts and i show 13 ma currant running as it charges .
i also built a 809 regulator circuit and put that on the 12 volt sla inside the amp , then got an ac adapter , 12 volts 300 ma , they are on a switch and they run thru the regulator .
i used some xlr cable 3 conductor , and i have 2.1 mm dc connectors that come out of the 90 degree  1/4 jacks . it works , but on high gfain patches i hear a high whistle interferance :(
surprisingly much less when its runnng off the ac adapter than the sla ...
any thing i could try ?
different cable , ferrite ring on the audio input , filter circuit ?
the 90 connectors i used are really cheep , and i do have some nice switchcraft 90's . the cable looked pretty good shielding . the input jack is an inline one , it doesnt grab too good . i didnt notice till it was done and its a bear to get at it !!
any ideas ?
petey twofinger
so i tried using ferrite thingies , i git em off the end of some power supplies . i tried em on the audio input and the dc .
didnt seem to do anything , what did eliminate 99 percent of that problem (high whistling interferance) was cutting the ground wire on the dc out put of the amp . the cable that feeds the sustainer . i cut that ground wire and the whine went away . the sustainer still functions because it gets grounded thru the main audio jack ground .
there is zero hum / whistle or whine when i use the ac adapter that is in the amp , when i run it off the sla battery thru the voltage regulator circuit i made it has LIL interference SOMETIMES , a high whistle / whine . its sporadic , you cant hear it while playing , and it only pops up on super high gain patches . this amp uses a korg pandora going into a ta2024 12 v amp module .
so i can totally live with it .
i charged the 9.6 volt nimh battery i got at 10.5 volts , with an old 9 volt battery charger , and it charged up good this time . i played for a half hour and it only dropped a quarter volt . i just wasnt charging it hard enough before . so i have a battery option too , besides the crap  lil 9volt idea ... i dont care for those lil guys much . they're great in some things but honestly i would rather not , ever .
this wasnt as bad as i thought . gonna make a back up cable and move on to something more interesting .
thanks !!
