2sk246 Subs
Started by ninjadave7, February 07, 2012, 05:51:33 PM
ninjadave7
Hey all, found an old schematic with a 2sk246 transistor.  Can I sub a J201 or 5088 or something like that?
david L
It's a JFET. I'd start with a 2N5485, 2N5292, 2SK30, etc. J201 may work, may not. Depends on the rest of the circuit, as J201 is quite a low Idss.
smallbearelec
Quote from: ninjadave7 on February 07, 2012, 05:51:33 PM
If it happens to be the BOSS FA-1, it's known to be a good preamp/EQ. The original FET is not expensive:
http://www.smallbearelec.com/Detail.bok?no=485
and is in stock.
I built the preamp stage to fiddle with on the breadboard:
http://www.smallbearelec.com/HowTos/BreadboardICDist/ICDist.htm
and made it work with both the OEM part and a J201. The JFETs that are out-of-stock right now will be coming back in the next few weeks as some of our "last buy" orders arrive.
Regards
SD
