Pots without solder lugs?
Started by nobodysweasel, February 15, 2012, 04:50:16 AM
nobodysweasel
So I'm getting ready to put in a pretty big order so that I can start building and have enough spare parts to allow for lots of experimentation.  I'm planning on getting pretty much everything from taydaelectronics.com .  Unfortunately, they don't have all of the pots that I want available with solder lugs - they just have three pegs (for mounting to PCBs?).  Will this be problematic when it comes time to solder?  I was also looking at Futurlec.com but none of their pots have solder lugs.  Is this a big deal?  Is there somewhere else that sells pots for cheap that would be a better alternative?  As always, thanks for any advice you might have.
bluesdevil
No problem, just bend 'em back at a right angle and loop your wire around it. Also if you snip off the anti-twist tab, save it to put in the gap of the split shaft.... keeps it from caving in when tightening the knob's set screw!
"I like the box caps because when I'm done populating the board it looks like a little city....and I'm the Mayor!" - armdnrdy
Quote from: bluesdevil on February 15, 2012, 05:18:04 AM
cool tip, ....i'll have to remember that... 8)
IvIark
Makes soldering simple, easy to add the odd component to the pot, and acts as a heat shield so very little heat is transferred to the pot.
I prefer pin pots now.
DavenPaget
Quote from: IvIark on February 15, 2012, 09:53:37 AM
I either perf them or i develop a entire custom board .
Hiatus
Paul Marossy
I used to do that if the only pots I could get locally were a PCB mount type.
I've also done that bending the pins thing. I like to use a bit of used desoldering braid for the gap of a split shaft pot, works very well.  :icon_wink:
gregwbush
Just don't over solder / over cook. I f'd a few pots in the past and now when i solder wires to 'em i make sure the pot is held at an angle (lugs down like 45) so the solder can't run into the workings of the pot
my 2 cents
greaser_au
#7
why not just get the right push-on knobs while you're ordering?...  :icon_twisted:
Before you install the pot in the case work out the length you need,  tin the wire & wrap it round the pin,  then solder... no problem!
david
nobodysweasel
Great responses guys!  Thanks
I like this idea.  Is that something that you can buy or something you made?  If it's something you made, would you mind sharing the image to transfer it to the PCB?  Thanks.
DavenPaget
I believe using wrapping wire with it's sleeve removed and wrapped around the lug would be fine .
I from the start used direct soldering of the wire without realizing i should have used wire wrapping wire , which i have now .
It's fine to use those AWG30 stuff , you aren't gonna put more then 15V right ? Neither are you going to put 0.3Amps ?
Hiatus
nobodysweasel
Stripboard!  Wow, I don't know how I didn't put two and two together on that one...major facepalm.
