Electro Harmonix Freeze clone?
Started by Jule553648, January 09, 2011, 01:28:52 PM
Jule553648
Is it possible to make a clone of this pedal?
It's a digital pedal, so it could be a software issue.
Is it possible?
hday
It really depends on what you're going for, IMO. You could probably achieve some cool resonant sounds with a delay on a feedback loop with a mix/blend pot into your clean signal. But I'm not sure that something as complex as the Freeze is worth cloning, as it doesn't really break the budget at a little over a hundred dollars and is designed and constructed well. Trying to simulate that effect might be a little bit easier, and more worth your time.
Taylor
Bard Morons
If you are willing to go a different route, it becomes relatively trivial to code something to do this.  For example, I wrote something simple to do exactly this in ChucK last night... it has a few bugs, but for an hour of work, it's a simple effort.  That does require a laptop in the signal chain (so associated hardware).  Just a thought...
