alternative to etching... with acid?
Started by ca cat, March 09, 2012, 03:18:45 AM
ca cat
http://www.instructables.com/id/How-To-Electro-Etch-a-Solid-Metal-Plaque/
has anybody tried something simmilar? I belive this could be used for enclosure etching, using toner transfer?
Jamin' with JaM IT FX - www.jamitfx.com
Seljer
Yep, I've tried it works well. I used an icecream tub of saltwater, an old computer power supply for 12V with an automobile headlight bulb to limit the current to 1 or 2 amperes.
Though getting the toner mask perfect is the crucial part, maybe even more than when doing it with acid, every tiny little hole in the mask becomes accented greatly, that and the undercutting issue.
fpaul
I've been getting parts together to try it but still a few days away from a test.  I'm trying to locate a source for photosensitive stencils to use instead of toner.
Frank
CynicalMan
I've tried and failed with this method on PCBs, but it would probably work better for enclosure etching. You'll want to do this outside, because you will likely get chlorine and hydrogen gas. I started my test inside but stopped once the room started to smell like a pool.
DavenPaget
Quote from: CynicalMan on March 09, 2012, 06:14:15 PM
Well you can trick people into thinking there's a pool somewhere near your house  :icon_mrgreen:
Hiatus
put your swimming trunks on when doing it... ;D
QuoteI started my test inside but stopped once the room started to smell like a pool.
Chlorine gas is seriously dangerous, way to go with your instincts. It can kill you, if you're lucky. If you're not lucky, you can spend months in the hospital as they try to put your respiratory tract back together.
artifus
