Ideas for this Enclosure...
Started by mwynwood, April 06, 2012, 08:39:56 AM
mwynwood
Hi everyone - happy Easter!  :icon_biggrin:
I picked up a blemished 1590BB enclosure from Mammoth for about $5.
It's been drilled for a footswitch, LED and 5 knobs/switches.
Can anyone help me think of a fun effect I can put in this bad boy?  :icon_cool:
Marcus Wynwood
My Build Blog
MarcusGuitar.com
elflicho87
fuzz factory?
mastotron?
or
skrewdriver?
ciao
Tube screamer with full tone stack.
.Mike
Of course, you do have the option of covering the top of the enclosure with either PCB material, or a piece of aluminum.
Then, you can build whatever you want.
I really like the painted sides, bare metal top look. :)
Mike
If you're not doing it for yourself, it's not DIY. ;)
My effects site: Just one more build... | My website: America's Debate.
Seljer
If you can't think of anything to utilise everything, I've had good luck with filling up botched holes with JB Weld or other epoxy then sanding them flush
JebemMajke
Alembic F2B, fet version, with bright switch.
blacken
In case you don't want some of the holes, I have filed holes in enclosures before using jb weld or something.  I think if you put tape on the outside and fill the hole from the inside it shouldn't be too much work it is still kind of a pain though.
Quackzed
i like the f2b idea as well as the tube screamer full tonestack.
a tube screamer is a really usefull pedal. with a tonestack where you can scoop the mids a bit...
i might try that!  8)
J0K3RX
Make one more hole and you can stick a Dr.Boogey in it... You can have Treb - Mid - Bass - Pres  on top and level and gain in the V pattern...
mwynwood
Wow - thanks for all the cool ideas guys.  :icon_biggrin:
Is there anything with 5 knobs/switches that is *not* a overdrive/distortion/boost?
Something a little out of left field maybe... could a Maestro FSH fit in this box?...  :icon_mrgreen:
Marcus Wynwood
My Build Blog
MarcusGuitar.com
Not sure about "left-field", but Rick's Causality 4 MkII is five knobs...
gruemungus
How about the Distortus Maximus?
Quackzed
clari not, parallel universe...
... burst box...
tyronethebig
EchoBase delay with a big knob for the delay time on the top right to manipulate with yo foot?
I'm not, not licking toads!
-Homer
Güero
Any of zillions TS clones + mosfet booster
Curing the infection one bullet at a time.
digi2t
Quote from: Quackzed on April 07, 2012, 12:01:45 PM
... burst box...
+1 on the Parallel Universe! I LOVE mine. It's a great LM386 based circuit. Version 2 that is.
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
nosamiam
Quote from: mwynwood on April 07, 2012, 06:23:28 AM
4ms Phaseur Fleur. It's great!
