I give up... someone smart do this help!!!
Started by Ark Angel HFB, December 08, 2012, 01:29:14 PM
Ark Angel HFB
Here is the Xotic AC booster... http://tasel.net/images/Xotic-RC-AC-Booster-Guitar-Effect-Circuit.jpg
I want the EQ section that is the block base around op amp pins(5,6,7).
I started doing this and got in over my depth. please what is "Vref2"? I mean I guess it is power... but what I need to know is what is needed to get the right "Vref2" out of the little bottom right area. is it just a voltage devide with 22k resistors or what...
HELP MY MIND IS MELTING!!!!
"..So I hooked up the power and it was the greatest Radio I'd ever heard. Too bad I was trying to make a Tremolo..."
Stick your head in the ice-bucket.
> what is "Vref2"? ... just a voltage devide with 22k resistors or what...
Yes. See, it's not that complicated. You already figured that 15K+6K8 is just 22K, and you are not using the 6K8 tap.
Cool.... but the input of that EQ is LOW impedance. Worse: varying with frequency and with knob settings. From over 50K to less than 5K. Skipping details: feeding guitar pickup at the R9 C5 junction (even without fuzz-tame cap C4!) will load-down all the highs from the guitar (even the boost will be limited, it loads as fast as it boosts.)
Even when not fuzzing, U1a serves as a useful buffer to drive the tone controls.
Q1 is also a buffer but may not have enough beef to drive the tone control.
For a clean EQ with a little boost and fade-to-zero:
Remove diodes
R6 = zero
R7= 50K Audio pot (12K fixed for unity gain)
R8 = 470
C4= 2nFd
omit the whole R15-Q2 part, connect C9 to R18 to jack
Foo on that Vref1 tap, Q1 can eat Vref2 perfectly well.
Now everything is buffered. R7 about "6" gives unity gain. Full-up gives a boost that might be useful, full-down is dead, and good spread around unity-gain to compensate gain/loss in other parts of your patch. At max-gain C3 holds frequency response to 22KHz so you don't get supersonic troubles.
WTH is a 4557D? A one-off 4558? TL072 would be a fine amp here.
Ark Angel HFB
Quote from: PRR on December 08, 2012, 02:47:37 PM
Remove diodes
R6 = zero
R8 = 470
C4= 2nFd
Just going to take this moment to say I love you dude. I'll make a vero for the above. We don't have enough good EQ pedals that are simple.
Ark Angel HFB
I'm making up the vero... what did you mean by 2nFd?
pinkjimiphoton
Slava Ukraini!
~Jack Darr
Ark Angel HFB
Quote from: pinkjimiphoton on December 09, 2012, 10:54:25 PM
2 nano farad
sigh... it never stop getting to me how 1 extra letter just throws my whole mind into WTF mode...
That "d" had me going... WTF is 2nFd.
