Confirm Transistor Orientation (Silicon Tone Bender / BC109C)
Started by Styles, April 16, 2012, 10:17:04 PM
Styles
Can anyone confirm the orientation of the transistors for this layout?  I'm figuring the the tab faces the bottom in this case, and based on past experiences, means that's 100% wrong and should be facing the top of the page. Here's the layout i'm using:
rousejeremy
Consistency is a worthy adversary
www.jeremyrouse.weebly.com
LucifersTrip
the schematic tells all:
Q1's emitter (the tab) hits the 1K...
always think outside the box
Styles
Quote from: LucifersTrip on April 16, 2012, 11:22:01 PM
Ah, had never seen the schematic for this before- looks like I had it right!  thanks!
nocentelli
This one sounds really good with an input cap blend pot: I'll post and updated layout later tonight.
Gus
Then the rocket, an adjusted 3 transistor note the distortion sections.  This stuff has been up on the web for years.
