Help/Confirmation of correct MXR Microamp Veroboard layout!
Started by sam21, July 06, 2012, 01:18:38 AM
sam21
hey guys, first post here.
Ive recently started out with experimenting on making my own pedal and i decided to start with an MXR Microamp.
I used the Schematics and wiring diagrams of General Guitar Gadgets. The only component I have substitued is a 500K normal log pot instead of the reverse log pot as it was very hard to find.
I am resonably profficient with a soldering iron with analogue circuitry like this (although not with SMD stuff, it scares me slightly haha)
Could someone just check my veroboard layout made in LochMaster and check that it is right to create?
here are the links to the schematics and diagrams (they r in a pdf) if they dont open/work, the 3rd link takes you the the generalguitar gadgets site where they are located.
http://www.generalguitargadgets.com/pdf/ggg_mamp_sc.pdf?phpMyAdmin=78482479fd7e7fc3768044a841b3e85a
http://www.generalguitargadgets.com/pdf/ggg_mamp_lo.pdf?phpMyAdmin=78482479fd7e7fc3768044a841b3e85a
http://www.generalguitargadgets.com/projects/15-boostersrouters/70-mxr-microamp-project
cheers (I did note after going over it the incorrect placement of the 2 leads which go into the ground track, and the ground lead, they are now moved down 1 track)
