12v Power Supply
Started by Ultrakd, July 15, 2012, 12:17:20 PM
Ultrakd
I need help, Im wanting to make a 12v power supply that has around 10v or more. Im not sure how to build one so if anyone could help me with a make one I would be greatly appreciated.
Guitars: Ibanez S570DXQM
Amps:  Peavey ValveKing 112, Roland 15XL
Pedals: Big Muff w/ Tone & Wicker, Original Crybaby w/Modifications, BYOC Overdrive 2, Danelectro Cool Cat Chorus, Boss PH-3, Wave Breaker Tremolo,
lonewolf
go to the tonepad site
they have a power supply project that is variable from 7-12v dc
Jdansti
LM317 Adjustable Regulator
Use a trimmer on the board for the adjustment pot (R2).  Omit the transformer and rectifier if you already have a DC power supply that is at least a couple of volts above your desired output voltage.
This is pretty much straight from the LM317 data sheet (http://www.ti.com/lit/ds/slvs044u/slvs044u.pdf)
