has anyone built this version? (superfuzz)
Started by Canucker, July 29, 2012, 10:53:19 AM
LucifersTrip
yes, according to the schematic there, that's the classic version...with a 3.3K at the expander and a 10K trim for the octave:
http://ustomp.com/files/superfuzzschem.gif
always think outside the box
Canucker
I use to say schematics make my brain explode...then it just made my brain hurt....now they just make me curious and help me debug my projects....and for my next trick I'm gonna lose my tail and walk up right! Did you use the suggested transistors? I've heard you can use a lot of different once and it doesn't change the sound to drastically.
LucifersTrip
Quote from: Canucker on July 29, 2012, 06:02:57 PM
solidhex (Fu Manchu) gave voltages from a killer sounding original:
http://www.diystompboxes.com/smfforum/index.php?topic=64068.0
I used transistors in the 150-200 (which someone on the other board measured from his original 828's) range, which gave me insanely close to those voltages, except for Q6. To get 5.75 on Q6C, you'll need a lower gain transistor (~ 60 -80) or alter a resistor (I experimented by altering the 15K from B to ground)
