Resistors Less than 100 ohms : Any use?
Started by RandomGlitch, August 02, 2012, 08:17:20 PM
RandomGlitch
I inherited a whole stack of resistors, and I'm now (inspired by one of chromesphere's videos, I'm sorting them all out logically.
It turns out I have a whole load of low-value resistors, ranging from 1 to 100 ohms.
I've never seen these used in a pedal circuit, do any designs use these low values? I don't like clutter and having stuff I will never use, so do I keep them or make them into some kind of art or just bin them??
IvIark
Quite a lot of pedals use a low value current limiting resistor in series with the supply, I've seen them as low as 10 ohms and up to 100 ohms in quite a few popular pedals.  Other than that I've rarely seen anything under 100 ohms used.
Cliff Schecht
I use high wattage, low power resistors quite a bit in tube amps. They can be used to drop the supply voltage, the heater voltage, to sense cathode current of the power tubes, to help reduce stress on a power transformer with a tube rectifier, the list goes on. In pedals you really only see small value resistors in the power supply circuits. I use a lot of sub-Ohm values for the current sensing resistor in power supplies.
I think your fingers got ahead of yourself.
Dropping heaters and sensing large cathodes, you may use high wattage, low value resistors.
(Though if you own a DMM with mV resolution, you use 1 ohm resistors under cathodes and these do NOT have to be high wattage at all.)
Low-value resistors have plenty of good uses:
  • As mentioned, limiting supply current.  Is your LFO ticking?  Stick a low value resistor between V+ and the V+ pin on the op-amps making up the LFO, and a 10uf cap from that pin to ground.
  • Limiting the lowest point on a control.  Look at the Big Muff "Sustain" control.  Does it shut off completely?  No.  And why would you want it too?  A 100R resistor between the ground side of that pot and ground, means that even when the knob is at 7:00 there is still a little bit of signal left.  There are plenty of similar applications of low-value resistors to pots.
  • I've seen plenty of distortion circuits where low-value resistors were used to "soften" the clipping.  Look at the Pocket Rockit here - http://hammer.ampage.org/files/PocketRockit.PDF - and you'll see such an application.
  • Low-value resistors are often used for "Zobel" networks on the output of low-power headphone-amp chips, like the LM386.
Nasse
Used to have zero ohm resistors, supply is empty, don´t know if they can be found somewhere
Very good for breadboarding and prototyping. There was a debate which was better zero ohm resistor or jumper wire. Quess I could made those myself if I had suitable wire and other stuff
Cliff Schecht
Quote from: PRR on August 03, 2012, 01:10:46 AM
Yeah you know what I meant :P.
LucifersTrip
always think outside the box
asatbluesboy
I love those 0 ohms. Jumpers make me feel like I'm cheating.
...collectors together and emitter to base? You're such a darling...
ton.
Skreddy
I'm using 10 ohms right now for the high-limit of the fuzz pot in Fuzz Face builds (put it in series with the 20 uf cap).  Depending on the build, a 100 ohm, 47 ohm, 10 ohm, or a jumper is appropriate in this spot.
waltk
Conversely, what about high value resistors? any use?
I have a bunch of old 1/4 watt carbon-comp resistors with values up to 22M.  Never use them for anything.
Seljer
Quote from: waltk on August 03, 2012, 10:17:11 PM
Ultra high input impedance pedals
High voltage projects (I mean really high voltage, not tube amps, if you ever decide to play with kilovolt stuff)
Quote from: Seljer on August 04, 2012, 05:05:49 AM
They can be used to bias diodes into conduction so if you have a rectifier-type frequency doubler, it does not cut out below a diode drop.  Most resistors have an upper voltage limit, so if I get a resistor over 10 megohms, I usually get it in a 1-watt size at least, so I can play with kilovolt stuff.
Pyr0
Quote from: RandomGlitch on August 02, 2012, 08:17:20 PM
No, they are just absolutely useless, get rid of the clutter and post them to me  ;D
marmora
I often use 10 ohm (or something similar) as a dummy load on the output jack of circuit bent toys.
chromesphere
Funny you say that.  On the weekend one the draws got stuck, a pot was jamming it and i had a temper tantrum while trying to 'forcefully' pull it out smashed it to bits :)
Those low value resistors arent used as much as 100+ ohm resistors from what ive seen but they come up occasionally.  I'd lump them all in a bag together for the odd occasion you need one.
Paul
Pedal Parts Shop                Youtube
RandomGlitch
Yes that's what I thought I'd do.
Smashed it? Ha, you seemed like a mild-mannered fellow before!  ;)
Think you need bigger drawers.
chromesphere
#17
Quote from: RandomGlitch on August 05, 2012, 11:19:59 PM
Ill assume by 'drawers' you mean underpants so thanks for the compliment :)
Smashed it then throw it across the room actually lol my inner guitarist breaks free every now and then. I was having 'one of those' builds and lost my temper.
Seriously need another cabinet though...with bigger draws...
Edit: For all the hardware...its always the bloody hardware that gets stuck (jacks, switches, and even pots).  Makes searching a time consuming process.
