decrease the volume of a guitar pedal..
Started by FUZZZZzzzz, September 04, 2012, 10:21:37 AM
FUZZZZzzzz
so.. i've breadboarded something cool.. but turns its extremely loud.. i could put in a volumeknob but that would be useless as it would be fixed around 20% all the time. is there a good/easy way
to decrease the overall volume without changing too much character? maybe put a fixed resistor in front of a volume knob? (thats the first thing that comes to mind)
can anyone put me in the right direction?
merlinb
A volume control is a resistor divider. If you don't want it to be variable then use fixed resistors instead of a pot.
Or if you want it to be variable but over a smaller range, the yes, put a resistor in series with the end of the pot.
FUZZZZzzzz
it's that simple? thanks for your fast reply! i will try tonight
