Alembic F-2B Preamp with SMPS Supply
Started by gtudoran, February 08, 2011, 04:32:49 AM
gtudoran
Hey guys,
Just finished my F2B preamp with Ecc83 tube - i used the stock schematic but i designed my own PCB (needed some specific dimensions). 12V DC supply @ 1.2A used for heaters and for SMPS supply - anode voltage is 280v.
Some pictures and 2 sound clips - one with cabsim and one without (directly into sound card, the guitar used was a Squier Strat SSS).
Best regards,
Gabriel Tudoran
Analog Sound
http://dl.dropbox.com/u/15275178/Pictures/250CC-NoCabsim.mp3
http://dl.dropbox.com/u/15275178/Pictures/250CC-Cabsim.mp3
gtudoran
Hey guys, just made another project, this time using 6N16B double triode - the main schematic is a Matchless HotBox (was done as an experiment ), the PCB it's done by me. The only difference between this and Matchless is that i used a BigMuff tonestack (i was a little lasy when i was making the PCB). So here there are some pictures and a little sound clip - the clip was recorded useing the ROG CondorCabsim.
Best regards,
Gabriel Tudoran
Analog Sound
http://dl.dropbox.com/u/15275178/Pictures/MasterDrive.mp3
MichelP
Great looking and sounding  builds.  :D
Especially the Matchless-type built with 6n16b tubes.  I´ve got some lying around here, I want that sound too !
One question however :
Have you allready built one of these in an enclosure ?  If yes is there any noise-issue when using this SMPS ?
I´ve built a McTube with this SMPS,  cool sounding but when I assembled  it inside an aluminium enclosure I got  noise.
gtudoran
No noise in a Al enclosure - use a copper band over the SMPS and use a separate PCB for SMPS ... you should have no problems with that.. ohh and one more thing IF you use the enclosure as a termal radiator for IRF (or any other fet that u may use) don't it will act as a antenna - better go down with HIgh Voltage and keep them cool but don't stick it to the enclosure even if you use a ceramic foil and some thermal grease.
Best regards,
Gabriel Tudoran
Analog Sound
MichelP
 :)Thanks for the quick response, I´ll be using these 6n16b´s soon then !
Renegadrian
Nice, I see you can get some quite cheap! I think I am gonna jump on that train too!!!  :icon_smile:
gtudoran
Wellcome in the boat :P if you need any help don't hesitate to ask!
Best regards,
Gabriel Tudoran
Analog Sound
Renegadrian
I bought 4 of them for 10 $ today - hope they will be here soon!!!  :icon_smile:
karolisd
Hi, could you please post the schematic of the SMPS that you used? Thanks!  ;D
