Can I build a simple active mixer using just MPSA18s?
Started by aeiou, October 02, 2012, 03:49:22 AM
aeiou
Is there anyway to build an active 4 channel mixer using just MPSA18 NPN transistors? Reason being -- It's all i've got on my desk at the moment.. that or a bunch of PNP Germanium transistors, which I'd be open to using as well.
~arph
Depends if you have any caps or resistors laying around  ::)
aeiou
yes yes, plenty of those here -- what i should have said is that those are the only transistors i have on tap.
~arph
 ;D
Yeah I thought so..
I see no problems building this mixer..
Build five buffers.. four of them each have their own volume control and then a cap.
All outputs of those buffers (after the cap) connect to the input of the fifth (no input cap needed ).
You can even add a little gain at the end.
aeiou
so i wouldn't encounter any issues dropping MPSA18 (bjt) into this JFET circuit?
http://www.muzique.com/schem/eagle.htm
~arph
I don't think that will work directly as that is a BJT for FET substitution and you might run in biasing issues. I suggest you use a simple BJT buffer instead. But it should be very similar.
~arph
Nasse
Four resistors will mix.
But the sum is weaker than the sources.
If your system has gain in reserve someplace else, no "active" is needed.
If not, you want a gain of 4 or so. Easily gotten with any BJT/FET in an appropriate circuit.
Jdansti
Would four resistors going into a Tillman work well?
Perrow
