Takamine preamp repair
Started by Gordo, January 17, 2012, 10:31:47 PM
Gordo
Does anyone have schematics or info on an older Takamine Accuracoustic preamp.  It's the one without the tuner.  It's surface mount components, which is bad enough for troubleshooting, but Takamine won't fess up to having a schemo for it.  They want you to buy a new preamp for $150-$300.  Ouch.  Trouble is that the thing is modular to the frame cut into the guitar (a Santa Fe) so it's not like I could just pop in a Fishman.
Thanks.
Bust the busters
Screw the feeders
Make the healers feel the way I feel...
Quackzed
no, but any moving parts ie jacks, pots , battery snaps <--- these always die, are the likely culprits, surface mount is pretty reliable except for board mounted pots / jacks.... chances are its something that encounters physical stresses...
so
1 battery jack/snap
2 board mounted jacks /pots
3 jacks / pots that arent board mounted...
...you could make an audio probe and check around those parts, see if/when where signal disapears...
59lespaul
#2
59lespaul
Older model Takamine preamp schematic from the 80ies (web find):
Fishman Natural preamp schematic
Zipslack
Make sure it's the preamp.  If any of the piezo goes, the whole thing stops working.  You may have 1, 2, or 3 pickups.  Also check the wiring at the piezo...thin wire, easy to break from vibration/movement.
Quackzed
this is a pretty old thread, just to let people know b4 they spend time on helping. hopefully its fixed?  :-\ we may never know...
