Quick Geofex Spyder question...
Started by digi2t, November 23, 2012, 09:32:59 PM
digi2t
Hi all,
Building myself (FINALLY) a decent power supply for my pedals. Daisy chaining blows, so I've put together a Spyder.
My question is concerning the LM317. Should I put heatsinks on them? I'm using 12vac transformers, I've touch tested them, and they don't seem to get past warm.
This is the layout;
and with the cover on
Sooo..... heatsinks? Or no?
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
It depends - sorry, you knew that was coming, right?  :icon_biggrin:
What it depends on is the actual raw DC you get and the load current. Those are the TO-220 versions, and I believe that the TO-220 has a 1.5A current limit. It also has internal thermal limiting. They look to be 12V/200ma transformers (??) which would indicate a 15-20% "regulation" sag from no load to full load. If you're running them with 100ma on the outputs, they'll sag nearly to the 200ma full-load voltage for some math reasons.
So raw DC is at most ~17.25V, probably a volt of ripple, so call it 16Vdc. If you're taking 9V out, the regulator will be dissipating the load current times the difference in DC voltage across the regulator, or 7V. So for 100ma load, the regulator will make 7V*0.1A = 0.7W.
A TO-220 can get rid of about 2W in free air. So at 0.7W, yeah, they'd just get warm to the touch. Somewhere about 250-300ma, they'd really need a heat sink, or they'd be shutting down from overheat protection at ugly, unfortunate moments.
Notice how sensitive series regulators are to the raw DC voltage feeding them. If this is only a few volts above the output, they can be remarkably efficient (that is, they don't get very hot). At the same load current, a higher input voltage can cook them. In this case, 23-24Vdc into them doubles the power they waste.
In general, if you can put your finger on it and keep it there, it's not under thermal danger - for "average" values of modern electronic parts.
digi2t
OK, thanks R.G.. With that variable on the table, taking a few minutes to throw the heatsinks on, is chump change to aviod an " ugly, unfortunate moment".  :icon_biggrin:
Thanks for the advice.
Cheers,
Dino
Dead End FX
