Which knobs/pots worth removing (i have too many of them)
Started by Rock_on, December 28, 2012, 05:00:41 PM
Rock_on
ok so i built this:
https://sites.google.com/site/distorque/home/projects/modded-electra-distortion
and i put a gain knob
clipping threshold knob
naturally it has distortion and volume knob... so right now i have 4 knobs and i like to add big muff pi tone...
(dont worry about the tone stack problems)
so what knob is worth removing??
If you've added the gain knob do you need the distortion knob as well? You can probably turn your guitar's volume down and get a  similar effect.
Rock_on
Quote from: slacker on December 28, 2012, 05:08:48 PM
uh hard question... what's the difference and what's the best configuration?
can you explain pls?? do you think gain much better than distortion??
Muthauzem
what slacker said is that there seems to be two knobs doing the same. looking to the schematic, you could remove the distortion knob, since you can use the pots from your guitar and get the same effect.
another option would be using a trimpot instead of a pot in the cliping threshold. tune it once to your liking and leave it there. it's a possibility
Rock_on
Quote from: Muthauzem on December 28, 2012, 06:02:01 PM
Oh thanks now I can add a new knob (if I can see any)
Btw in a OD where is the place of drive pot?
