Infinitphase vero.
Started by digi2t, December 30, 2012, 08:13:14 PM
jishnudg
Quote from: alanp on June 02, 2014, 01:11:44 PM
Yeah, I thought I had shielded wire... turns out I don't. I need to order some.
isn't it possible to roll those yourself? read something about "Pseudo Balanced Wiring" or something like that...
@alanp - if you have an old pc monitor, cut the video cable. you get inside 3 colours of shielded wire and 4 (6?) of stranded. should do the job.
" I will say no more "
armdnrdy
RG174/U is a fairly common shielded coax. Check to see if any local brick and mortar suppliers stock it.
