Transformer Isolated ABY Pedal
Started by tristanplaysguitar, January 13, 2013, 10:29:25 PM
tristanplaysguitar
Hi
I need to build an A/B/Y pedal, and I'd like to put in an isolation transformer to avoid ground loops. But, it needs to be true bypass with no buffer. Basically a bare minimum passive ABY Switcher with a transformer.
I've found this: http://www.geofex.com/FX_images/humfree2.gif
but it has a buffer.
and this: http://www.tonebone.com/re-bigshot-aby-detail.htm
But I don't know if the radial diagram is a complete schematic. If it is, would this transformer work? http://www.mouser.com/Search/ProductDetail.aspx?R=42TM018-RCvirtualkey21980000virtualkey42TM018-RC
Or does anyone have any other schematics?
Thanks,
Tristan
<a href="http://tristan-smith.bandcamp.com">My Music</a>
Guild Bluesbird, Guild GAD-25, THD BiValve
Built: LPB-1, Bazz Fuss, BYOC Analog Chorus
Transformers have problems, especially at high impedances.
You can not build a naked transformer good enough to pass high-impedance guitar perfectly.
If you buffer, it is not too hard.
