morley aby box.. how to add wall wart adaptor
Started by TWANGONE, January 14, 2013, 05:58:34 PM
TWANGONE
I found a lot of schematics but all using different switches and confusing me further than when I started.
two leds, two spdt stomps, but only the battery to power it
and of course I've already left the silly thing plugged in twice and drained the battery,
I can fit the adaptor in there but I'm not sure how to do it.
probably being lazy... feel like crap today
TWANGONE
The light on the Morley pedal will stay ON if power is plugged in.
This means if you leave your board or pedal powered you can see the light and turn it off, since you shouldn't leave your power
to the pedals when they are not being used anyway.
continued:
TWANGONE
this was front mounted because rear mounting might mean a prob. with something like a 1 spots jack to jack length.. and keeping the board neater for wires.
notice it's mounted nearer the bottom plate side because the board would stick into it--so watch your drilling.
can be used w. or without battery I think, that is, the power should not deplete w, the adapt. used. could be wrong!
at any rate, no more battery for me.
