Idea for an ultra simple and cheap power supply
Started by Ghost Planet, January 23, 2013, 05:26:27 PM
Ghost Planet
This idea came to me driving home from work today. What if you used this voltage regulator
http://powersupply88.com/wp-content/uploads/2011/06/simple-9-volt-psu-300x171.gif
Then powered it with an old laptop power supply. As long as the laptop power supply has enough amps to supply the pedals and you slap a heat sink on the IC it should work, right? It's cheap and simple. What do you all think?
gcme93
Datasheet says C1 0.33uF and C2 0.1uF
Any reason you're going for a lot higher than that?
Piss poor playing is why i make pedals.
Ghost Planet
No I just pulled the layout from google images and that's what it had listed. So no, no reason. Would there be an adverse effect of using that high of values?
gcme93
It's just a very basic low-pass filter I guess. For example, your version's C1 starts cutting out frequencies above 7kHz whereas the datasheet suggests 480kHz. You're right, there's no difference, and actually your version is better for cutting out unwanted frequencies. (just did the maths behind that which was a nice bit of revision :P )
As for the schematic, it sounds good, and is nice and simple. Should do the job well - the datasheet says it can handle 35V! After you've got your heat sink on, make sure you do the highly technical P.R.R test:
Step 1. Wet your finger
Step 2. Place finger on metal heat sink
Step 3. Check for fizzing noise/burning sensation
If Step 3 = true, use bigger heat sink
If Step 3 = false, sit smugly and enjoy 9V output
Ghost Planet
Cool! I figured if you had the power supply lying around collecting dust why not use it for something. I hear reduce, reuse, recycle is the way to go these days.
petey twofinger
mine is still chuggin along , use it erry day .
http://www.youtube.com/watch?v=MtiZRGfSGBI&list=UUzL6Rp7DwrTOfNq84mxlJ2A&index=21
i think the ps ia 18 at 2.5 a . i used a tin , like a cookie / candy tin so the chassis acts like a heat sink . i did fuse it . i prolly shoulda went with a lower value quick blow fuse . i reverse polaritied my compressor and toated a cca3080e . got an lm3080 in there now , but i just found a bunch of both in some pcbs i pulled out of an organ  :icon_redface: hmmm .
im learning , we'll thats what i keep telling myself
greaser_au
Quote from: gcme93 on January 23, 2013, 06:12:45 PM
suggested update:
Step 3. Check for fizzing noise/burning sensation,  or mirror image of manufacturer's logo branded into fingerprint   :)
david
defaced
Most non-budget DMMs come with a thermocouple.
-Mike
