cool reverb apart from switch spdt 'pop' issue
Started by deadastronaut, January 28, 2013, 06:49:11 AM
chromesphere
Quote from: aballen on June 12, 2013, 04:56:21 PM
Ok, I just got a long brick in the mail for my tenebrion reverb, but after seeing the demos for this I think I'm building one of these.
Would anyone be interested if I had a few boards fabbed up?  It might take me a bit to get it all right in eagle, but once that is done, OSH park gets me boards pretty quickly.
R O Tiree offers the PCB's for purchase already.
Paul
Pedal Parts Shop                Youtube
+1 :  mikes boards are the nuts. 1590b sized too.. 8)
aballen
Are his boards etched or fabbed?
I can etch one myself... but I really prefer the plated through holes on a fabbed board.
So many builds, I just can't list them anymore.
haveyouseenhim
Does anyone here have a belton brick they would like to sell me?  Antique Electronics supply has @#$%ed me over again. When I ordered it, it CLEARLY said in green letters "In Stock"
But I got my package today and there was only a switch that I ordered. I called them and they told me it was on back order till mid July. ALL OF MY RAGE!   This happened last time I ordered from them. I'm done messing with these people....they have a 100% failure rate.  I suggest if any of you order from them to call in the order.
http://www.youtube.com/haveyouseenhim89
I'm sorry sir, we only have the regular ohms.
R O Tiree
Quote from: aballen on June 13, 2013, 12:14:25 PM
They are not plated through, but they are soldermasked.
...you fritter and waste the hours in an off-hand way...
haveyouseenhim
Nevermind... I talked with the supplier and changed it to vertical mount (which I can make work) and I got them to send me a free shirt after a little fuss. First time they messed up it was ok,these things happen, but the second time the exact same thing happened and that's not ok. So I got a little compensation :icon_mrgreen:
jmasciswannabe
A quick questions for those of you that have the dry level control. If you turn the dry down completely does the wet signal thats left reach unity? If it doesn't, is there a way to correct it so that it does?
....the staircase had one too many steps
jmaguire
Quote from: R O Tiree on June 11, 2013, 06:00:35 PM
I realised earlier today that I had not implemented the Oscillation mod. I've just now finished that.
Here are the new v1.6 files:
Layout
PCB Art
Schematic
How much for 2 of these PCBs including shipping to Ireland please?
Quote from: jmasciswannabe on July 02, 2013, 02:22:45 PM
sorry haven't had a chance to try the dry mod out yet, but i do have a brick on order to try it out , i will probably breadboard it again and test it .
eventually... :)
haveyouseenhim
#209
I just finished wiring mine and now comes the debugging. I'm not getting any dry signal. When I turn the dry pot up all i get is the faintest barely audible distorted dry signal that almost sounds like white noise. In the morning I'll try putting pin 1 of the dry pot to ground instead of virtual ground and see if that makes any difference.
Edit    I couldn't wait till morning. I tried lug one to ground and got the same thing.    Any suggestions? Has anyone built it with the dry mod yet?
haveyouseenhim
jmasciswannabe
Quote from: haveyouseenhim on July 19, 2013, 02:49:57 AM
Anybody? :icon_cry:
I adapted this dry control to a similar circuit using the above described method and it worked fine, except that when I took out all the dry there was a volume drop with just the wet. That's why I was wondering if anyone had completed it on this circuit and the result.
Jdansti
Re: Wet/Dry Mix:
First, keep in mind that I have no idea what the hell I'm talking about. ;)
I looked at Merlin's Equinox reverb and he has the back end arranged like this:
A couple of differences are that he is using a TL072, and he doesn't have a JFET on the output from the reverb chip.  I'm thinking that there shouldn't be any major differences between the outputs of the bricks vs PT2399.
It may not work for this application, but it looks like an easy mod to try.
pastiche
Hey guys, I just did up a bom/component list so I can refer quicker (making a few) - am I blind or is there no R10?
pastiche
Guessing it might have dropped out from an earlier schem
pastiche
#216
Sorry, double/ triple post. Getting used to tapatalk... :-\  :icon_redface:
R O Tiree
Quote from: pastiche on August 09, 2013, 08:06:08 PM
Go with the schem and layout I sent you in my email. There is no R10 in there. I suppose it was inevitable that differences would creep in between deadastronaut's original diagram and the various versions of my layout as suggestions from forum members were incorporated.
Here is the BoM generated from ExpressPCB/SCH:
Capacitors
C1   100n
C2   100u
C3   47u
C4   47u
C5   22n
C6   100p
C7   100n
C8   1n
C9   1u
C10   47n
C11   22n
C12   100n
C13   100n
Resistors
R1   10k
R2   10k
R3   1M
R4   2M2
R5   10k
R6   22k
R7   10k
R8   10k
R9   10k
R11   33k
R12   10k
R13   33k
R14   1M
R15   8k2
R16   1M
R17   68k
Semiconductors/ICs
D1   1N4148
D2   1N4001
Q1   J201
U1   LM78L05
U2   TL074
U3   BTDR-2H
Controls
DAMP   10kB   pot
DRYMIX   10kB   pot
FDBK           10kB   pot
RVB   22kB   pot
VOL   47kB   pot
OSC      SPST switch
SW1      SPDT switch for Bright/Warm selection
Hope this helps.
jeromeplank
any know if it would be possible to add an effects loop on this verb? i'd like to play around with adding stuff to the wet signal a bit. maybe get into some modulated reverb territory.
