cool reverb apart from switch spdt 'pop' issue
Started by deadastronaut, January 28, 2013, 06:49:11 AM
merlinb
Quote from: samhay on November 01, 2013, 12:23:12 PM
^if i remove R11 / 33k from vb, i lose all verb..
That I don't understand either. At the moment, IC2d is just an inverting amp, just like IC2b and IC3b, so shouldn't need a bias restor to (+) input to function.
The (+) input does need to be connected to Vb, it just doesn't need to be connected through a resistor- a direct connection is better (resistor just adds noise). I think Deadastronaut may have simply misinterpreted and removed the resistor altogether, breaking all connection with Vb.
therealfindo
Quote from: alanp on November 02, 2013, 01:55:53 PM
Kick-ass, once you post a final schematic I might work on a layout in eagle if that's OK...
BTW, If anyone was to get some pcbs fab'd, I'd put my hand up for one - I had a headache soldering the self-etched board last time, because of the tiny traces..
samhay
Quote from: merlinb on November 03, 2013, 07:04:43 AM
Good point...
Oh, and Rob, have you worked out how to do the switching with this now that it is working.
hi sam, guys..
not yet, spent a day recovering yesterday, celebrated a little too much...(i need to respect that famous grouse whiskey a little more) :P
anyway,  this will be a lot of fun using a footswitch to play over the trails...and just have a toggle for TB . thats the way i fancy it anyway. 8)
ok, here is what i have now, the basic 'no frills' reverb. without hi/lo switching,
going to try out a tone control instead of that moody damp pot..
merlinb
Quote from: deadastronaut on November 04, 2013, 07:09:17 AM
You need a resistor between the volume pot wiper and C1, otherwise the pot can short the (-) input of the opamp to ground. 1k will do.
okey dokey, schemo ^ updated.
notes:
the overall volume works with both reverb and sw2 bypass.
there is oscillation just using the 33k.( R5)
btw i have  3pdt toggle switches too...
edit: correction, vol works only in reverb...
there is a tiny tonal difference between TB and sw2 bypass....but very tiny.. :)
merlinb
Quote from: deadastronaut on November 04, 2013, 07:49:17 AM
If you want a master volumr control that is active all the time, then replace R2 with a variable resistor. I'm not sure why you would want to do this though. Surely you would always want unity gain in bypass mode?
yeah thats not a problem merlin...
i was just making notes for myself really.. ;)
samhay
#608
I think this will work for the switching (foostwitch on the left).
nice one sam...
thats a mad setup eh.. ;D
just been tinkering with the feedback/decay resistors.  33k mass osc/ 100k tameable even fully on. (for more subtle reverb stuff)
so if we went with just buffered bypass, tails...( which i am coming round to thinking that's all i would use in the real world anyway)
no tails =  nasty..
we could make life (switching) nice and simple eh.. 8)..plus the buffer near the end of my chain might be handy too..hmmm..
thoughts?.
hell we could just use a nice alpha DPDT ..and 2 leds.. 8)  (ignore the resistor  values etc)
hmmmm...bummer, i can still notice a tiny pop still when ''playing and switching only''.... :(
doesn't pop when inactive though.....bugger i thought that was cured.. :-\
https://dl.dropboxusercontent.com/u/7464107/poppydaybummer.mp3
i'll try 1M resistors to ground on SW 1 3...see if that finally nails it totally. edit( nope)
samhay
yeah - the switching idea needs testing and it would be a lot simper if you were happy to do away with true bypass.
Good luck with the pop.
yep i think we'll do away with TB...sounds great as buffered anyway..
apart from this damn @#$%ing @#$%er pop, its only whilst playing though...hmmmm strange... :-\
no love for a poppy switch then?..
heres a clip of switching constantly through silence, great, until you play (which i why i thought it was cured)  then it pops like a mutha with sound going through it,...then disappears as the 'sound' fades off too...
https://dl.dropboxusercontent.com/u/7464107/popperpig.mp3
ive tried 2.2M resistors to ground from out of input and output caps ..as option 2 suggested by RG (geofex)  the 3rd option he gave was 'live with it'  ::)
ive tried 2.2M's from sw2 lugs to ground also....kinda running out of ''not wanting to live with it'' options... :-\
any ideas?.
merlinb
Quote from: deadastronaut on November 05, 2013, 07:13:11 AM
Do you still get any voltage on the switch?
0v on both sides...
and 0v when being strummed on both sides..weird!.
samhay
#616
What happens if you replace C15 with a smaller (preferably non-polarised) cap?
Edit: Did you true a pull-down resistor from lug 2 of SW2?
BuGG
I know it's a long shot, but does it still pop with the LEDs removed from the circuit?
Quote from: samhay on November 05, 2013, 08:58:09 AM
yep tried replacing that cap, no joy..
sw2: . resistor to ground instead of just ground,  yep but still pops and lets reverb through too.
@bugg: there is no led in the circuit yet..(the above switching was for when it was sorted..)
i think we may have to go the electronic switching route...slackers echo base type thing. :icon_idea:
I think i have some 4066's..from when i built it.
what about these?..from andrew
http://www.thetonegod.com/tech/switches/switches.html
samhay
#619
Quote from: deadastronaut on November 06, 2013, 03:50:32 AM
The cap was a long shot.
I meant a pull-down resistor from the switch side of R21.
Electronic switching is not guaranteed to be pop-free either, but it may be an interesting learning experience.
