HELP!!! Blend Knob on a TS, not true bypass
Started by juan_felt, January 29, 2013, 12:23:03 PM
juan_felt
Hi everyone!
So, I wanted to use a TS clone for a bass guitar and I added a blend knob (as suggested in the forum).
The schematic I used is this one: http://diy-layout.com/29
It works fine, but the only problem I have is when the pedal is off. If I don't turn the blend knob all the way to "clean" no sound comes out. It seems it's working as a clean volume knob. Also, if I disconnect the power supply from the blender, there is no sound coming through.
HELP!
Thank you..!
juan_felt
The switch was wired incorrectly.. Solved it.. THANKS!
