Dipthonizer builders: mods?
Started by Morocotopo, February 01, 2013, 08:56:30 AM
pinkjimiphoton
man i was a fool. the modern lm13600 version sure ain't the old one.
tried the specc'd 13600, ended up going for a 700 instead, seemed to track better
all mono ceramic caps, electros all tants except the 100uF
tl074 for the quads
5232 for the dual
i forget which cp i used, it was whining so i shorted pin 1 to pin 8, no more whine
for the detector part of the circuit silicon diodes really suck.
it quacks much better with ge... i used two 1n34's as they were convenient. made the thing more touch sensitive
also changed the fuzz clipper to asym ge/si as i did originally... two 1n34's in series, cathode bands to ground to clip the soft(er) clip the top of the wave, one 1n914 band away from ground to clip the bottom.
now it starts behaving more like the old one.
for the cap c2, i like 1n on this one, but i found on the original it sounded and tracked better with nothing there. the cap is just to mellow the fuzz a little,  so it comes down to what sounds good to your ear.
i may remove the cap down the road.
i suspect i modded or fudged some values on the original one, bugger me for selling the damned thing without checking bean's forum first to see if i could build the earlier revision still. i gotta whole sleeve of 3080's still.
on a plus note, it fits nicely into a 125. i gotta rock this thing live tomorrow to see how it matches up. hard to tell in the dungeon.
Slava Ukraini!
~Jack Darr
pinkjimiphoton
oh yeah, while researching W(hat)T(he)H(ell)ID(id)
on the originals, i used 240k resistors instead of 220k
r21 i used a 10k trimmer instead of the stock 1k.
hope that helps some future formant adventurer
Slava Ukraini!
~Jack Darr
