Getting the paint to stick to aluminum.
Started by jhferguson, February 04, 2013, 08:00:24 PM
j-pee
how miraculous it could have been if jhferguson (OP) had reported back, say, on Feb 11, in 2013, what had happened that time around, using all the advice...
GibsonGM
He's been too busy mass-producing custom hand-painted enclosures...  :)
Strategy
I can't say I've tested this scientifically but I've observed on two recent paint jobs that I overestimated the speed of drying, or maybe a better way to put it is that if I followed the recommended dry times on the paint can instructions, this wasn't enough time really before doing a lot of work on the enclosure. On these projects, the paint was peel-ish (not as bad as the original poster's example, but not great adhesion) within the first few days, but after about 10 days I couldn't get the paint off unless applying a blade (I was intentionally experimenting with this to test durability). It's like the paint really took some time to 'cure' and 'settle' on. I now add multiple days to the stated drying time on the canister, especially giving a lot of time before adding on panel components like washers and nuts which will apply pressure to the painted surface.
Strategy
www.strategymusic.com
www.community-library.net
https://soundcloud.com/strategydickow
https://twitter.com/STRATEGY_PaulD
anotherjim
Don't use countersunk slot head screws/bolts. The ends of the slots act like cutters when you tighten them up.
GibsonGM
I'm a house painter; a little different as I mostly deal in latex, but I am old-school enough to know about oils and lacquers too.  Yes, paints will say "allow 24-48 hours to dry between coats" and things like that. The truth is, paints don't CURE for weeks.  Both acrylic and solvent based.
When I paint something, say your kitchen cabinets - you can touch them in a day.  But if you scrape them with a fingernail, we're back to square one. They will be vulnerable to this for a few WEEKS, depending on temperature.   Try painting a door outside when it's almost raining and 42F, LOL, you'll see some 'dry time'.
There is a lot of logic present when we see people talking about using old toaster ovens to bake their paint!  Just don't burn it :)
